Wiring help please...
So I just got done changing suspension and bars on my 1996 EGC. Took air shocks off the back and front. The front air ride had a wire running to it that is now disconnected. I also put on 14" bars. Needed new clutch cable, but not wiring and added brake line. Put her all back together and my wiring is funky. Here are my issues:
1. All fairing lights click on and off
2. Radio clicks on and off
3. No lights work (headlight, passing lights, brakes, running, or turn)
4. The bike cuts off randomly as I'm riding and then kicks back on sometimes...other times I have to hit the start button again.
I have checked all my quick connect harnesses and everything appears to be grounded.
Any ideas? Im at a loss. Fuse? It's older so I have a bunch of aluminum houses fuses and no tester. Bad ground? Loose wire shorting something?
Thanks
Thanks
