Power Vision / Tuning question
Auto tuning in weather that cold will give poor results when you get back in summer temps. Was told never to try auto tune under 50-60 deg weather. Will throw ve out of whack and your idle should always be in open loop. It should have a somewhat rich smell as that is what will keep your motor cool in the hot temps unless you have a wet head.
Auto Tune plus gauge observation
Finally installed the PV on the handlebar and set up the gauges to monitor mpg, throttle position, engine temp and volts. What are others monitoring? I have noticed since my initial tune, my mpg has dropped to below 35. I need to run a full tank to get a better average but it does seem low.
Question, I am ready to run an Auto Tune. Can you run an auto tune and also observe your gauges or will the PV only log one task at a time?
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
There is a sticky thread over in the tuning sub-forum that has about a million posts on the PV. These things aren't silver bullets, you need to know a little about electronic engine control theory. Maybe I'm just a tweaker, but I've run hundreds of AT sessions over time as I make changes to the bike. I have multiple 'production' tunes I keep stored in the PV for different reasons. I also review the logs with Megalogviewer HD to see what the bike is really doing while I ride it during an AT run.
Every engine breathes differently even given the same mods, and continuous tuning helps dial in YOUR engine's personality. You can't take a vendor's tune for your package, do a couple of AT sessions and expect it will be a great tune.
I don't know it all (not even close), just saying that expectations should be set appropriately. You can have the best of both worlds, crazy on acceleration and great mileage while cruising, you just have to do more than run a couple of AT sessions and have and understanding of what's going on in the ECM.
