handlebar riser flex
Tighten them up some more. I put WO577's on my bike last winter. I used Drag Specialties poly bushing. Torqued to spec, seemed a little too loose, gave them a 1/4 turn till they felt firm with very little slop. Now, 10k miles later, they're feeling a little loose. I'm going back in this winter and snugging them down again.
Harley sells riser bushings that are solid aluminum. I have never used them, but hear they don't create too much vibration. That's always an option.
the more rigid the bushings- the more vibrations are transmitted- bad for guys with carpal tunnel.
but with taller bars you have more leverage so you need to balance out the slop.
it's tough on touring models but try to tighten your bushings while feeling for vibrations in the bars
