All Balls 25mm wheel bearings compaired to stock.
#31
I have the Pit Posse tool. Works well. Bought it on Amazon but at the time I bought mine it did not come with a 25mm adapter. I think the idea is that you can use the 3/4" adapter on a 25mm bearing but I have heard that it doesn't work that well. I have 1" bearings so no issues.
#32
#33
I should also add that I pressed out and pressed in the bearings in the rear drive sprocket with a 10 ton shop press. I used a piece of 2" Internal diameter pipe under the sprocket to press the bearings out and the 25mm install adaptor from my Georges Garage wheel bearing tool to press the new bearings in. A very light coating of anti seize on the bearings outer race helps considerably with the install and should help if they need to come out again in the future. The stock bearings are put in dry and come out fairly hard.
#34
Received 4,632 Likes
My grandson has used the Pit Posse.
I coat the outer wall of the bearing and the wheel mating surface with anti seize, more for getting them out again than putting them in. I also coat the puller threads and washers with grease; a tight bearing can take a lot of pressure to seat (tip: freeze the bearing just before putting it in to shrink it a tad). George's, Heartland, Pit Posse, and el cheapos on ebay look very much the same. The first three all have good reviews.
#35
#36
Click on Technical Reviews, scroll down a few. It is reprinted from The Horse/ backstreet choppers
www.Dragbike.com/worldwidebearings
#37
Wow... That was a really interesting read. Had never heard of the ceramic hybrid bearings. I'm sold. On the puller/installers, which of the 2 kits George's Garage or Heartland is the best for the 25mm bearing pull and install? Looks like the Pit Posse has 25mm install issues. And do they come with instructions? Haven't used them before.
#38
#40
