Towing behind motor home
Old 01-08-2016 | 07:10 PM
Rick Osgood's Avatar
Rick Osgood
Originally Posted by us1fountain
I was at a Rural King today and made an effort to look into the utility trailers. Several models/sizes to choose from that would meet the OP's criteria; load carrying rate and cost. I'd buy the one with the largest tires myself.
You get a brand new trailer with new tires, hub assemblies, flooring, frame, lighting.... etc. A rock guard is easy to add if needed. Granted, a nice enclosed is best if one can be found within his specs for added security and uses, but it's not always a gotta have or go without condition.
Trailers that are used within the quidelines are no more of failure risk than your tow vehicle.
Preventative maintenance is a wonderful thing. Makes trips more enjoyable.
Not familiar with Rural King... what is it and where do I find them?
  #62
Old 01-08-2016 | 07:31 PM
CVO SG's Avatar
CVO SG
Sorry, just assumed it was a national chain. Its a farm implement store, like Tractor Supply Co. Our TSC also has trailers. Might worth looking into
  #63
Old 01-08-2016 | 08:00 PM
Uncle Paul's Avatar
Uncle Paul
Thinking outside the box. Have wife drive the motorhome, and you drive the Harley.
Keep the $1,000 in your pocket :>)
  #64
Old 01-18-2016 | 10:02 AM
Rick Osgood
Love the idea but that ain't happening
  #65
Old 01-18-2016 | 10:07 AM
Rick Osgood
Ok gang, I have been back and forth on this for weeks and here is where I am at... I will be going with the Harbor Freight trailer (1790 lb model). I will be re-enforcing the frame at various points to ensure stiffness and structure integrity. I will also be changing out the stock 12" 4 ply tires to 12" 6 ply tires. I will also add the bearing buddies to make life easier. This configuration I can tow behind the MH as wife drives car.
I would really like to hear from anyone that owns this trailer or the same size trailer to understand if there are any issues with the bike length. Mine is 96" long tip to tail and 65" wheel to wheel.
Thanks
Fishrrman
09-17-2015 02:56 PM
Broncobilly72
EVO
14
01-28-2013 11:57 PM
osirisdean
11-09-2011 02:19 PM
rematt
02-18-2008 07:27 AM
promet1
01-08-2008 10:10 AM
Quick Reply: Towing behind motor home
