Street Glide Brake upgrade
Old 12-30-2015 | 09:10 PM
dojodragon's Avatar
dojodragon
Default Street Glide Brake upgrade
This weekend I was playing around with some crotch rockets in traffic, and even though my brakes work good I was wondering if their maybe a viable upgrade option. I have a 2012 street glide w/abs. Thank you for any advice.
Old 12-30-2015 | 09:38 PM
JMC22's Avatar
JMC22
Performance Machine 6 piston calipers if you think you need to stop quicker...
http://www.performancemachine.com/mo...e-caliper.aspx
Old 12-31-2015 | 12:10 PM
OldPhat's Avatar
OldPhat
^ Ya That.
Old 12-31-2015 | 12:56 PM
qtrracer's Avatar
qtrracer
I think you are limited to 1 6piston caliper, although I'm not certain, due to amount of fluid needed to pressurize 12 Pistons in a dual set up. Maybe there is a m/c that would work with dual 6 Pistons. I wouldn't think 6 Pistons would be an upgrade over 8.
Old 12-31-2015 | 02:02 PM
Sierra977's Avatar
Sierra977
Is your SG a Rushmore? If yours has Apex linked anti-skid brakes that's all the brakes you will ever need. I would not mess with that system. It's smarter than you can be.
Old 12-31-2015 | 02:34 PM
GTK's Avatar
GTK
Naturally when a bike weighs 200-300 lbs less then a Street Glide,it going to feel as if the brakes are better.Add the difference in weight and then check the stopping distance.
Old 12-31-2015 | 05:13 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Brembo's are some of the very best engineered brakes in the world. You can possibly do a little better but not by very much. Try some EBC or Lyndell pads. You'll notice a big difference over the stockers.
Old 12-31-2015 | 05:29 PM
Sierra977's Avatar
Sierra977
Mind if I ask which EBC or Lyndell ceramic pads you used? My Thunderbird has EBC Red Stuff ceramics and they are very good on an automobile.
Old 12-31-2015 | 05:46 PM
qtrracer's Avatar
qtrracer
I personally don't find Lyndall pads as good as the oem Brembo pad.
Old 12-31-2015 | 08:44 PM
BigTwins's Avatar
BigTwins
I agree... the brembo pads are darned good...they have pretty much nailed the balance between performance and durability.
Quick Reply: Street Glide Brake upgrade
