Mods If You Could
I just did a list of 14 things to do before summer. Some small some bigger but not as big as your dreams. Most costly being coolers & true track link & bushing's for the old swing arm. Just want to keep my 88 C.I. running smoothly with the rubber side down.
Want to test ride a RG in the spring.
Have thought seriously about converting my Limited over as well. Lovin it the way it is for now.
Reverse. Yelvington or Baker for handlebar control.
Brake caliper actuated anti-dive mechanism on the front forks.
Externally adjustable damping for the front forks.
Fully adjustable rear shock/spring assembly.
Custom seat & modified frame to let me get my feet solidly on the ground and ride all day long comfortably.
Narrower primary.
ABS upgrade. Not exactly sure who's, and it would have toggle switch control.
Air conditioning. As long as we're fantasizing. When it's 100+ in the sun, I want to be cooled off. Wouldn't mind heat either, but wired heat in the clothing does suffice.
Narrower primary.
