? on FP3 need help
Old 12-29-2015 | 04:35 PM
rick's Avatar
rick
Default ? on FP3 need help
I have a 15 SGS originally with cfr slipons.Heat was a killer.I added the V&h dresser duals and the fp3. Upon install of the fp3 called V&H on the initial setup.Was told to run thru a gas tank and then if needed do the autotune.They said I probably wouldn't need the autotune.Well bike stalled a few times at a light. Not happy. Did the autotune and don't think I did it right.Now when throttling regardless of gear I'm in it would sputter and bad throttle response.As if not getting gas. Has happen a few times. While throttling all of a sudden no throttle but then it would.What are my options or what have I done wrong.Tried V&H several timestoday but haven't been able to get thru.
Old 12-29-2015 | 04:56 PM
glock35's Avatar
glock35
Are you still in Autotune mode? The bike will run like that when in Autotune mode, at least that's what I found on mine. Once the Autotune was ended and the map changes made, it ran great.
Old 12-29-2015 | 05:16 PM
Jaystn62's Avatar
Jaystn62
Try downloading your original map and see how it runs. Be sure to exit the auto tune first.
Old 12-29-2015 | 06:00 PM
rick's Avatar
rick
After the auto tune I hit done. I'm assuming that's the exit . Unless there is a different way.
Old 12-29-2015 | 06:14 PM
tbrince's Avatar
tbrince
Sounds like you just finished auto tune and didn't apply learned values or flashed tune to your bike.
Old 12-29-2015 | 06:45 PM
Jaystn62's Avatar
Jaystn62
I don't think he should apply the learned values until he finds out if there's a problem with the FP3 or his bike. I'd download original map and see how it runs. Probably will run lean but should tell something.
Old 12-29-2015 | 06:50 PM
rick's Avatar
rick
I'll recheck again tomorrow but I believe it said flash complete. Now I didn't apply anything. Not sure where that came into play I probably missed that entirely. I just auto tune via phone . I bet I'm just doing this all wrong . Probably not going about it the correct way.
Old 12-29-2015 | 06:52 PM
Jaystn62's Avatar
Jaystn62
Wait!!! Did you download a new map for the changes you made or are you trying to auto tune the original map?
Old 12-29-2015 | 07:06 PM
rick's Avatar
rick
The one v&h sent me. Originally on initial setup.Told them the pipes I had and we went thru the selections.( no cfr) first. After wards when I tried the auto tune there were 2 maps but only 1 had a (1) the other 0. So I selected the 1. Not sure if that makes sense . But how I remember it.
Old 12-29-2015 | 07:29 PM
Vernal's Avatar
Vernal
This might help?
Good Luck
Quick Reply: ? on FP3 need help
