Brake Light only wire? 2016 Road Glide
12-29-2015, 03:34 PM
Hey all I am trying to figure our where I can get a brake light only 12v source. Currently I am tapped into the Right Rear Blinker which causes all my LED's to go red when I stop or when my right blinker is on lol.
Thx
12-29-2015, 03:42 PM
HD has used a red wire with yellow stripe for brake light.
on most models this is available at the ACC plug so you don;t have to splice or cut into wiring if that scares you
mike
12-29-2015, 03:43 PM
Hmmm the red wire with Yellow in the the rear wire harness has constant 12v to it for some reason. I plugged into that one first after looking at some wiring diagrams
12-29-2015, 03:50 PM
acc plug pin out for most year models ( confirm this yourself) is:
pin 1- Orange Red- P&A circuit
Pin 2 - Red/Yellow- Brake light
Pin 3 - Orange- Acc switched
Pin 4 - Black- Ground
I'm working from older model wiring diagrams
mike
12-29-2015, 03:51 PM
Quote:
Originally Posted by
mkguitar
HD uses a red wire with yellow stripe for brake light.
mike
I know that's true on my '12, but is that also true on the Canbus bikes?
12-29-2015, 03:54 PM
Turns out it was the Blue/Red Stripe ....... weird
12-29-2015, 04:01 PM
ehask71
Just checked the 2015 Touring service manual that is the color for the brake light output.
05-28-2018, 03:15 AM
ehask71
Where did you find the wire? I am trying to add a brake light.
05-28-2018, 11:30 AM
Randy Oblong
Start at the brake light and trace it back to where you can access it.
They usually go from the light through the fender, inside the fender and comes out under the seat where it joins the main harness. Also, as mentioned above, the ACC connection is wired with a brake only line.
05-28-2021, 12:37 AM
Brake light wire
I just did ambother led set up on my bike 2021 rg, the wire that needs to be tapped is blue with red line for brake on rear harness
Bubseth
Electrical/Lighting/Alarm
13
06-15-2017 10:27 AM
casey73
09-30-2013 03:27 PM
theoapodaca
02-21-2011 01:15 PM
Fupl18
02-09-2009 03:49 PM
Gregte
05-19-2008 07:39 PM
