Secret Tool Revealed:)
Old 12-27-2015 | 08:42 AM
sr230mike's Avatar
sr230mike
I have seeping where the clutch cable goes can you get the cover off far enough like this to disconnect the cable?or just tighten the bolts??
Old 12-27-2015 | 08:54 AM
roussfam's Avatar
roussfam
If your trans is over full or the breather tube is plugged, oil can actually travel up the inside of the clutch cable then seep out. If it hasn't been touched the Oring at the end of the cable is probably fine. Be careful if you try to snug it up, doesn't take much to snap. Ask me how I know.
Jim
Old 12-27-2015 | 11:08 AM
crimson13's Avatar
crimson13
Good idea , thanks for posting.
Old 12-27-2015 | 06:46 PM
09UltraRyder's Avatar
09UltraRyder
Default Perfect timing
Perfect timing of this post. have some down time and needing to do a few things on the bike while the weather is bad. This was one of them.
Old 12-28-2015 | 03:20 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I loosened the exhaust bracket carriage bolt to put copper grease between the two plates/sides. This seems to avoid corrosion due to friction.
DSBSAV504
10-20-2015 09:10 PM
mkguitar
04-28-2014 10:33 PM
UltraClassicElectraGlide
09-07-2013 12:47 PM
Throwback
General Topics/Tech Tips
10-08-2012 01:54 PM
lo-rider
03-28-2011 08:04 AM
Quick Reply: Secret Tool Revealed:)
