Ultras no tour pak
Old 12-25-2015 | 07:31 PM
Longridertx's Avatar
Longridertx
Filakus, I have that same paint on my 15 Ultra
star2nv's Avatar
star2nv
I found this . I believe it will mount to the mounting holes where the turn signal bar mounts.
Old 12-25-2015 | 07:51 PM
mkguitar's Avatar
mkguitar
Krapkin I don;t use any of their stuff.
if you get a plate mount...you have to figure out how to light it.
Mike
Old 12-25-2015 | 07:58 PM
DiscoBayJoe's Avatar
DiscoBayJoe
this bracket came with the detachables kit
Old 12-25-2015 | 08:01 PM
nickrat's Avatar
nickrat
For a light, I got a short LED strip at AutoZone that I put on the bottom of the turn signal bar and wired into the fender tip light.
Old 12-25-2015 | 08:04 PM
rizzo's Avatar
rizzo
Used LED lights in the bolts.
Old 12-25-2015 | 08:21 PM
TSheff's Avatar
TSheff
[QUOTE=DiscoBayJoe;14688221]this bracket came with the detachables kit
If you like that look OK.
LIGHT?? Now there are tail light lens with bottom windows.
Old 12-25-2015 | 08:29 PM
Cozz's Avatar
Cozz
Default Cleaned up rear end
Here is what you're looking for maybe . If you take a mounting plate like disco joes, and re drill the bolt holes in the angled area just above the original holes, it will lay down really nice. Then a nice frame, and your done. All for dirt cheap, and it looks great.
Old 12-25-2015 | 08:34 PM
fer79's Avatar
fer79
2006 flht Electra Glide standard
Old 12-25-2015 | 10:20 PM
cc89iroc's Avatar
cc89iroc
I used a road king light on mine
Quick Reply: Ultras no tour pak
