2009 4 point docking hardware install
You will need to get the docking hardware specific chrome strut covers with the holes in them. They come with the kit ( 53246-09C) when you buy it. The left & right side strut covers are available separate (47502-09A - left & 47504-09A - right). I know this as I ran into the same situation. Priced them individually and as I recall they were stupid high. Fortunately found them used form a member here on the forum Good Luck!
There are 2 different kits. 5230013 for the newer models and 54205-09A, 54246-09A for the older models. If you look them up and reference the assembly instructions you will see the difference. Because it was built with the tourpack I am not sure if you require different side plates as well.
I have the 4 point docking kit on my 2009 electra glide,, All I know is, that if I upgraded to a , (I think), a 2014 up touring model I would have to buy a different design 4 point docking kit to fit , as mentioned above .. Looks like you have the docking kit to fit the 2014 up touring bikes ....
This is the kit you need to fit an 09 UC:
http://www.harley-davidson.com/store/-pa-02-5324609b--1
I'm assuming the strut covers in your pic are the original ones off the bike. As I mentioned, you need the 4 point docking hardware specific strut covers that come with the correct holes in them. If you click on the above link, then click on "More Info" you can click on a PDF of the instruction sheet. On the last pages (5 & 6) is a parts breakdown of the kit...you either need the complete kit or item number 29 & 30. In the parts breakdown you will see the strut covers with the required holes in them.
I "McGivered" mine below the brake light with a bracket fro SoftBrake.
