Battery - HD OEM or AGM, or other?
Old 12-05-2015, 01:55 PM
Road Star's Avatar
Road Star
Road Star is offline
Veteran: Marine Corp
Default Battery - HD OEM or AGM, or other?
I guess I need a battery..
Haven't ridden the bike in two weeks and can't get it to start. Tried the battery tender, but it's not working. Prior to this, I have been riding the bike every day, to and from work, etc. Now it's not starting - damnit!
HD OEM is $184, aftermarket AGM from Oreilly Auto Parts is $134.
Are HD OEM batteries better?
Old 12-05-2015, 02:01 PM
mid30's Avatar
mid30
mid30 is offline
I get the big crank from batterymart.com. oem seam to last but trying out the big crank cause of what people said about it here.
Old 12-05-2015, 02:08 PM
Road Star's Avatar
Road Star
I got the AGM #EXT30LA, had it I think two years. Wondering if the HD OEM is better?
Old 12-05-2015, 03:14 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,838 Likes on 2,548 Posts
EastPenn batteries make the DEKA sport battery, an AGM battery and as far as I know still the provider of the HD battery, which an AGM type battery. Find a dealer near you and they may be able to get you one. Most sport batteries give you a one year warranty. May try AutoZone or PartsPlus for a direct replacement.
Old 12-05-2015, 03:18 PM
burleyburl1's Avatar
burleyburl1
burleyburl1 is offline
agm all the way but get the right charger
Old 12-05-2015, 04:01 PM
TurboChris's Avatar
TurboChris
TurboChris is offline
I went with a Shorai lithium battery in my Road Glide after having had one in my Kawasaki for several years. Weighs 5 lbs! and starts my big twin like no other. Pricey at $250 on amazon but customer service is terrific and so far so good.
Old 12-05-2015, 05:33 PM
Brewmany's Avatar
Brewmany
Brewmany is offline
Do you have a regular battery charger available? Battery tenders might not bring back discharged batteries where a regular charger might. If it will take a charge, get it load tested, then you'll know if you really need a new one.
Old 12-05-2015, 09:58 PM
seniorsuperglideE8
The applicable charger would be a smart tender, one that charges to 14.2v. then monitors the charge and automatically charges when the monitored charge drops. A good charger would be from Deltran.
Old 12-05-2015, 11:12 PM
wscott's Avatar
wscott
wscott is offline
Your going to pay way too much money going that route @ Hd & OR OREILY for same type fact activated maint free agm batteries so chk these out to save big bucks.
scott
DEKA ETX30L 400CCA $87.99 INC S&H FROM: (HIGH-TCH BATTERY SOLUTIONS)
This is the same battery that autozone sells under their name or battery marts BigCrank with is same deka battery under their name for considerably less money money not to mention HD's lower output agm repl battery @ approx $170+ retail./YIKES!!!/LOL!!
http://www.techbatterysolutions.com/...FUKQHwodZAwDxw
HERE'S ANOTHER TO PONDER.
3YR WARRANTY MAINT FREE AGM BATTERY WITH A STOUT 442CCA FOR $95.88
http://www.ebay.com/itm/191722257339
Here ya go ,A FEW more batteries with good prices on upgraded more powerful Maint free fact activated AGM stock type batteries.
Stock HD repl fact act mant free AGM battery is 385cca at a whopping $170-180 retail price.
These same type maint free fact activated agm batteries are higher output @ 400cca , 420cca & 500 cca at as much as $100 less for a quality Deka 400cca AGM battery then hd's lower output way overpriced repl battery.
See below links for details.
Scott
http://www.batterymart.com/p-mtx-30l...-fl-flh-1570cc
http://www.ebay.com/itm/Deka-ETX30L-...item1c573cfe0f
http://www.batterymart.com/p-Big-Cra...L-Battery.html
http://www.ebay.com/itm/121429861963
Old 12-06-2015, 12:15 AM
NuckaMan's Avatar
NuckaMan
NuckaMan is offline
Same situation as the OP. Woke up recently SUPER early (4AM) to get a head start on long day ride and the bike would not turnover...battery was shot. Figured due to age of battery, letting it sit for 3 weeks without a tender, and the 40'ish degree weather....made life hard on it.
Searched around and decided to go with a BatteryPlus battery. Yeah, it was expensive (got the Duracell AGM) but came with a 2-year warranty. So far, happy with it, plus they were open on a Sunday and I was back on road by lunch.
Quick Reply: Battery - HD OEM or AGM, or other?
