changing spark plug wires
I have a 2015 ultra limited. I had the stage 1 put on. I read upgrading spark plug wires with low resistant ones would also help. I was thinking of getting the screaming eagle wires. Would they help? My question: I went down to try to get the original wires off. It obviously wasn't hard to take off of the spark plug, BUT the other end does not just pull out. Is there a trick to getting it out?? Any thoughts would be appreciated.
This thread ran several years ago but will give you an understanding of ION Sense
https://www.hdforums.com/forum/engin...explained.html
The Screaming Eagle wires will work fine and the ION sensing will still work just fine as will the Fuel Moto wires. There will be no improvement unless your stock wires are not up to par, as stated previously. My SE wires have been on for 4+ years and been on a dyno 4 times where any spark issues, either false readings or failure to read, would have shown up.
Thats true that newer gen bike could throw a code if using much lower resistance type spiral core high perf wire plug wires let alone other plugs of diff design etc then stock that may also have different resistance .
Scott
