2015 dual bulb headlight in a 2005???help
#43
The "kit harness" for the 13 and back bike's has a diode, or some kind of device built in. The harness for the 14 up bikes does not. The 14 up bikes use the newer Can-bus electrical system. With the newer bikes, the dealer can connect it to a digital tech and program the ecm to allow power to the high and low beam at the same time. In another thread, a guy posted the part number for an older headlight kit that included a harness that is supposed to work for this application. If purchased separately, that harness is a lot cheaper than the dual halogen harness that comes with the kit for the 13 and back bikes.
https://www.hdforums.com/forum/touri...headlight.html
#44
It will work, but if your using it on a 13 or older bike, only high or low beam not both. I have basically the same harness, mine was custom made to run 2 - h9 lamps. I was running h9's in both the high and low beam, because the h9 has a higher lumen output than the h11. You will have to use a diode or relay in order to get both lamps to run together on high. As I posted earlier in this thread, the diode will rob you of some voltage.
#46
#47
How about your owners manual?! If you don't have one you may be able to download one from the H-D website - go to the Owners tab.
#49
#50
Uncle Larry (08-10-2016)
Wakko47
02-17-2013 01:21 PM
