Cruise Control Shutting Off
my 2010 would drop out sometimes when i hit a bridge joint, my 2013 has done it a couple of times too.....at the same place. thanks for the comment about the brake, that might be what is doing it. it comes back on when you push resume. odd yours goes off. gonna have to give the "stealer" a call probably.
Roll Off Switch
I have a 2001 Road Glide. I can set the Cruise Control and ride for a bit with it on and all of a sudden it shuts off. I don't think it is in any of the safety shut off switches because it will not Resume, I have to Set it. After I have Set it, it will go for a short distance again and shut off. Any suggestions?
On the right side of the frame in front of the gas tank is the roll off switch. You will see a black rubber cover on the idle cable. There are two conectors under the cover. Unplug them both and then try your cruise. If it works, the switch is bad. Youy will need to replace the cable. Be careful when trying this you will not be able to release the cruise by turning the throttle back.
Mine was doing the same thing so I did what Mike 79 suggested and walla the dam thing has worked for a week. I just removed one wire in the throttle switch, that I have looked at a hundred times and didn't know what the heck it was. Thanks Mike79 for the spot on solution for my problem, you saved me at least 120.00 dollars. Jj
I have a 08 SG. My cruise started to shut off on me, then it wouldn't come on at all. I was checking the grip and switch area, where I noticed the lower switch box. I sprayed some contact cleaner in the openings holding a towel under it. I let it sit for awhile, been working fine ever since. It's worth a try. JR
