Speedo Rebuild????Where????
I have a speedo that died and got a new one from HD - Also made sure I got the old one - Would like to get it rebuilt - digital type part # 70900072a.
Any suggestions? Could try Switzerland where they are made but would be easier to keep it in the US.
Thanks for reading....
It would seem like that part 70900072A is a:
COMBO ANALOG SPEEDO/TACH-5MPH/KM/H
Neat looking speedometer.
Looks like it might be for :
Fits 04-11 Dyna®, 04-10 Softail® (except FLSTSE) and 04-13 Road King® models (except FLHRSE3/4) equipped with a 5 Speedometer.
Died is rather vague.
A quick google search revealed a V IN ER error reported for that unit that required a reset.
Suggestion was:
1. Pull the “MAIN” Maxi fuse.
2. Hold the “trip” button down while re-installing the main fuse.
3. Speedometer should light up and appear as though it is locked up.
4. Release the “trip” button and turn the main key switch “OFF “.
5. Turn the main key switch on then, using the trip button, verify “R LO” is displayed in the odometer window when cycling through the options.
6. Re-initialize the ECM by cycling the main key switch on 30 seconds / off 30 seconds, 3 times.
Suggestion was:
I work in a Chevy dealership and we use a company by the name of Model Electronics. They supply our clusters on a swap system, they send you a rebuilt one and you send your old one back. From time to time there are no rebuilt units from them and we can send a unit in to them for repair. Might be worth a call.
www.modelelectronics.com
There is a phone number on the site I believe.
I had one just crap out and figured I get this one repaired as a spare...Would it be worth it......new they list for $314.
im....it died - nothing but the Red idiot light was one. The reason I put it on a thread I was hoping someone may have used someone they were happy with. I did do a google search and there a few around but just checking.
Received 49,978 Likes
most forums after suffering a bit of ridicule and criticism,you will get a real answer from a real person...
captjeff (11-16-2021)
