Wheel Bearings
I have had both ABS bearings replaced on my 2013, the rear at 10,000 and the front at 15,000 miles. The rear had a rough spot you could only feel when it was on a static wheel balancer. The front one just started getting noisier as time went on. The dealer tried to blame it on pressure washing but the bike has only seen a garden hose other than a few trips in heavy rain.
"What do you recommend for suitable replacement? "
There are no alternatives for the HD abs bearing, which is handy, as they, in my experience rarely give out. Its normally the normal standard bearing that gives trouble.
When it goes (twice in my own ride) it's good practice to replace both, so its a new HB abs bearing and a different standard...I have used Allballs with no problems.
The standard bearing is a common size and any 'branded' bearing will be better than taking a risk with another HD one.
The first version of the single row bearings 9276 were flawed and should be replaced ASAP. They will fail. These Indian made bearings were replace with better quality bearings in the second version 9276A. I can't remember which supplier provides the OEM 9276A bearings it is either SKF, Timken or F.A.G. All three suppliers can provide the better quality 9276A version, each of course has their own bearing numbers just cross reference. Amazon has a Made in USA Timken version. The ABS bearing is a little harder to source and until recently there were no non OEM versions. Brock's now supplies a ceramic version of both the ABS bearing and the 9276A. If anyone wants I can look up the bearing cross reference numbers, can't remember them of the top of my head.
