Auto-Tune question
Auto-Tune question
Hey gang,
The other day I started an Auto Tune session. What I'm curious about his how do I know, when the device is ready to Export the Learned data? Every time that I ride, do I have AT learn? When is the process finally done and over? Also, each time that I'm using AT and then exporting the learned data, is it going into the same map to make 1 ultimate map?
Unless i missed it, I don't think the manual discusses this?
Thanks all!
Thanks all!
Lots of answers to these questions, but basically ride 20-30 minutes at different speeds,rpms, throttle postions to fill in the counts on the table. When done export the data to a unused slot on the PV. I always like to then load it on my PC and see what adjustments were made to the VE tables. Then you can load that map back into your bike and enable that map for AT. Do another ride and then repeat until the VE changes are all lower than 2-3%
There is a really good thread on this whole subject, I thought it used to be a sticky but don't see it anymore
I guess what I'm also getting at and I don't know if this can even be answered but, how do I know when I have the perfect tune? Seems like, every time I ride I can AT for 30 minutes and save it. Is it a matter of "feel" or will the unit give me an indication?
Thanks!
Thanks man, we're expecting the first freeze this weekend, so I'll have lots of time for reading.
Thanks!
Thanks!
Then load map3 back in the bike and run another AT on that map.
When you get to the point that you don't see any delta's larger than 2-3% between the previous and new map then you have a decent map to stick with.
That would be a basic/general method, if you want to more complicated you can then run some AT's on timing and have it adjust the timing, but you really need to read up on all that before attempting it.
Hey gang,
Thanks all!
Thanks all!
I would and date time the location the run file ext save, with auto tune then you can always load a previous tune if need be..... Altho i never needed to... It will be done when there is hardly and change to the numbers cannot remember the percent but like 4
And if your not using a SERT ignore all that and have a
I called Fuelmoto and they walked me through it the first time. It is easy as can be. I did a few short like mentioned 20-30 mile rides and then went on some all day rides. Each time the % of trim got smaller.
Now every once in a while I plug it in and check .
Bike runs friggin awesome now all the time !!! I think the auto tune was the best investment yet for me.
Since it is colder I should probably check and see where things are at.
