Motor stumbles!?
#31
RE: Motor stumbles!?
Son, did the button reset this morning and took it for a ride. Still misses between 2000 and 3000, but it didn't seem to be as much, or maybe it was my imagination.
I checked the map you got from Jamie with the one he sent me and they are identical. Glad it worked well for you -- for some reason my bike just doesn't do well with it. I bought my bike used from it's second owner, so wonder if maybe mine has a different HD download than yours.
Oh well, having my bike dyno'd later today, so I'll let you know if that does anything to help.
#32
#33
Yes I have but i believe it is just sound bouncing off roads or other structures around me. I travel the same roads to work and I hear the noise at the exact location every time and when i get vehicles around me I can here it is well! I dont think it is anything with the exhaust being faulty they are just loud and sound great!!!
#34
Add me to the list as well...
'06 SG
SE AC
SERT
Rineharts
Mine was running great after a dyno tune, then about 2 weeks ago, intermittent missing... Changed the spark plugs, changed the Air Filter, and checked everything I can. Thought now is:
Map in the SERT is not stable
Convoluted hose leak
Jammed Fuel Filter
Intake Leak
Wet Connector
It is off to the shop I go... Time number 10 for this rig!
'06 SG
SE AC
SERT
Rineharts
Jammed Fuel Filter
Intake Leak
Wet Connector
