Oil pressure gauge at 60
I noticed riding last night that my gauge was pegged at 60, at idle it would jump from 50 to 60 nothing less. Just changed the fluids 2 weeks ago and level is good.. This morning I went out to want it up to see where it's at, as soon as I turn the switch to run it jumps to 60. Oil light is workin and everything else seems fine.. Rode 200 miles yesterday with no issue.. Any ideas guys?
If its a stock oil pressure gauge its electric so since its showing 50-60psi when you turn in ign sw without motor running yet i'd check to ensure connections are tight & clean on connectors on sending unit on motor block and on back of gauge in faring too.
Also chk to ensure there are no pinched & or shorted wires too.
If all that checks out ok then either sending unit or gauge is NG in which case i'd use factory shop / srv'c manual for test procedure to determine which is bad.
scott
That's my plan if action when I get home.. Currently at a rally so I dnt have those kind of tools with me
dwelch
08-24-2016 03:13 PM
