Check engine light
Check engine light
Situation:
1. At startup check engine light illuminates and then goes off which is normal
2. When riding check engine light and sometimes security light illuminates and then goes off (happens frequently during riding)
3. I found and cleared codes, checked fluids but situation continues to happen.
Would appreciate any guidance/advice on whether this is a serious problem and if I need to take to dealer or if I can troubleshoot myself.
Thanks in advance for any information provided.
Looks like you already know how to pull codes, but anyway - for reference.
http://www.fuelmotousa.com/p-29661-h...ble-codes.html
Probable coming from mods and piggyback connections or from careless unplugging and making connections. Wait to they reappear and take to a qualified dealer.. U0141 - Lost Communication I think? B1306 make sure the wire to the oil level sender is making a tight connection. Make sure of the battery connection and it is fully charged with a two day continuous run of the maintenance charger.
kyle.GEESH DUDE!!!!!!!!
Do we have to hold your hand too!/LOL!!!
Someone just gave you the link to hd error codes right above your post,why dont you take your time to look up the codes you listed?
Scott
Scott
