ROCKOUT rocker shaft inserts installed
Old 11-01-2015, 09:26 AM
dawg's Avatar
dawg
dawg is offline
Received 3,227 Likes on 1,842 Posts
Eunoterpsia (YOO-noh-TURP-see-uh)
The doctrine that pursuing sexual pleasure is the goal of life.
Old 11-01-2015, 01:53 PM
Panchorelly's Avatar
Panchorelly
Panchorelly is offline
Default Upon further review
Did about a 260 mile ride this morning. I think I am going to say that.....THAT tick is gone?.. Although I do still hear some valve train noise , which I am sure will always be there. Overall the engine is soooooo much quieter.
Old 11-01-2015, 02:29 PM
beasleyiv's Avatar
beasleyiv
beasleyiv is offline
Originally Posted by Eunoterpsia
I did notice the two fairly small holes... did you notice a reduction the first time? I wonder if the holes are larger in the newer whips?
Not much, that's why I drilled them bigger. The first time I went to ⅛". This time I took them out to 9/64". The breather element is supposed to stay off the bottom a bit so the oil doesn't get trapped, but I don't see that happening. When I installed the new ones this time I stuffed them up into the housing as much as possible and hope they will stay off the bottom of the rocker support plate.
I already have my ventilator modified, but I still would like to get that oil back in the crankcase and not on the ground. I think I got a fairly bad crank from the factory. Wish I could use the S&S reed valve but the newer engines have set screws on the crank bearing so it can't be installed.
Old 11-01-2015, 10:07 PM
Eunoterpsia's Avatar
Eunoterpsia
Eunoterpsia is offline
I installed the new (and revised) breather element assembly and maybe it does a better job (doubt it based on its function) but it certainly is not robust. Basically, you pop the breather valve in, insert the mesh, and the "cover" is a sealed piece so the mesh of the breather element makes full contact with the bottom of the rocker housing.
I wish i would have drilled those holes a bit larger but oh well... not going to be repeating that process anytime soon (I hope anyways).
Old 11-01-2015, 10:22 PM
JustDave13's Avatar
JustDave13
JustDave13 is offline
Received 15,100 Likes on 6,141 Posts
What holes are you guys talking about? I'll be going into mine sometime this week or next so if there is an improvement to be made ...
Old 11-02-2015, 08:20 AM
Eunoterpsia
The two small holes.
Old 11-02-2015, 06:38 PM
JustDave13's Avatar
JustDave13
They're oil drain holes? How wide should they be drilled?
rottnutz
08-14-2016 10:13 AM
Crashone
EVO
28
04-07-2015 08:08 PM
kino44
EVO
41
07-04-2014 11:11 AM
just plain john
Engine Mechanical Topics
02-18-2014 05:10 AM
notarheli
Exhaust System Topics
09-10-2008 10:20 AM
Quick Reply: ROCKOUT rocker shaft inserts installed
