when do you check yor PSI in your shocks?
#31
RE: when do you check yor PSI in your shocks?
I cleaned my bike yesterday and took off the Saddle Bags. I saw the rear valve on theleft side and it had 6 lbs. I brought it up to 15, mostly ride solo. Where is the front valve and do you need to take the bags off everytime you check it?
thanks
thanks
#32
#33
RE: when do you check your PSI in your shocks?
ORIGINAL: db2753
thanks
thanks
I guess they did away with the adjustable air front shock on the Electra Glides a few years ago. The crash bars were used as an air reservoir with a valve that shut to the front shocks as an anti-dive feature on quick stops - nice setup. The front schrader valve was located under a screw off end cap on the left hand grip.
You can get to the rear valve byopening the left bag lid.
#35
