Maintenance Mode
Maintenance Mode
I was doing some work on my 08 Ultra today which involved disconnecting the battery, I put the bike in Transportation Mode thinking it wouldn't alarm when I unhooked the battery, I was wrong. I've heard the could be put in a Maintenance Mode which I think prevents the alarm system for going off even if the battery's disconnected. Does anyone know how to do this ?
With fob present, turn ignition on, this will disable the alarm. You can then pull the maxi fuse or the battery.
Transportation mode only disables the motion sensor.
There is a service mode that allows you to leave the bike at a dealer for service and you can take key/fob with you. I thought dealer did that using digital technician, but could be mistaken.
Twinrider
11-03-2012 08:46 PM
