Touring Shocks
I truly believe that Ohlins are the best shock if you don't mind spending the money on them.
I have had stock , progressive, and now Ohlins, and I wish I would have started with the ohlins, because they are custom built for me ,by motorcyclemetal.com
I have no experience with legends Revo shocks.
I have a pair of legend revo-A's. Thought they were stiff, worked with legend and they had me send them back to them. They thought something may be defective. They have them now and I'm waiting for a verdict.
I have tried pro-action and super Shox and thought they were also stiff compared to my 13" stock air shocks. I'm almost convinced the air ride may be the smoothest. Of course the big bumps may be pretty harsh.
You will probably have better results no matter what you try because it doesn't get much worse than those 12" SG shocks. Anything is a step up from there.
I've been down this road and learned the hard way. Listen to the suggestions and go with the Ohlins from the beginning and save wasting your money getting there. The Ohlins setup by Howard ride fantastic and you will be completely satisfied with your decision. I have tried the stock, then went with the HD premiums. On a previous bike I have used Progressives. After going to Ohlins I will never run anything else.
Three important things to consider no matter the shock brand. Go with the longest shock you can. SG's are a crippled with 2" of travel. Second, go with a custom built shock. ie spring size and valving for the rider style and weight, 1up or 2up or a balance for both. Third, get a rebuild-able shock.
This leaves you with Ohlins and Works Performance. Works Steel Trackers are no doubt the best bang for the buck. Made in USA, custom built, rebuild-able and are made in custom lengths of 1/4" increments. Being 6'2", I went with a 13 1/2" shock that has 4 1/2" of travel. Almost enough suspension travel to qualify as a 20th century motorcycle.
I have them and they are very good shocks but you're not really saving any money from what I have seen. They do take some time to break in though. I have about 600 miles on them and they ride very well.
