Yes: another thread on cams...
But of those listed it's tough call. OP says 3-5k rpms so not caring if bottom range is a little soft, 555 would be it.
I ran the Woods TW 555's in my 11 RK, 96" and VH pro pipe. It did wake the bike up but I didn't realize the full potential of these cams until I bumped it up to a 103" with ported heads and 10.5 compression. I ride 99% 2 up and wanted the power to pass without having to downshift in most cases. The torque really came on around 2800 rpm and pulled hard to almost redline. I now have a 15 Ultra Classic and trying to decide which route I want to go with it to match the performance I had with my RK.
While we sell Wood cams exclusively, we have many Power Vision maps for Andrews, SE, and other cams and offer unlimited tuning support for these products as well.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Thanks Jamie but I still don't know which cam to choose. I wish there was a cam which affects all RPM's instead of just low end, high end.
Jamie - 2013 SG - stock motor with screaming eagle burst breather, screaming eagle pro-tuner II, Fuel Moto jackpot mufflers and ceramic x-pipe (decatted). Recommendation on which cam would give me mid-range power and torque? My priority is for the bike to have more power and torque from low-mid range and to give it a good "cam shaft" sound. Thoughts?
I too ran the 57's. Damn good cam. You can also use the stock pushrods, so that cuts your cost down in addition to the Andrews cams being alot cheaper than any of the Woods products.
I now run a FM 107 kit with the 777 cams. Alot more top end noise due to the aggressive ramps on the Woods cams. I've always heard the 555 &777 cams like compression.
