like I said, the assembly is not loose. The button itself has a lot of play in it. At idle you can clearly hear it rattle around. It actually sounded like static on the radio. My exhaust is rather loud too, DD and CFR's.
Common problem, I have it too. I took it apart & really saw no way to make it tighter.
Someone a while back posted something about putting an o-ring around/under the button but I never tried it.
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
It's the first complaint I made to the dealer about my Limited. They said there is no fix. It rattles at idle and going down the highway the rattle turns into a buzz. It's annoying so I just turn up the volume on the radio.
Try bending spring plate to add tension. This way when closed, that tension takes up the slack in lock and quiets down. Add some grease paste too inside lock
