Rocker Cover Gaskets. A must?
Hey all. I'm about to do the rock-out bushing on my '16 Limited. It has just under 2000 miles on it. From images I've seen, looks like the rocker covers use o-ring type gaskets. With this few miles on it, is it a MUST replace, a SHOULD replace, or a DON'T WORRY ABOUT IT deal?
Not that I'm trying to "save" money. I just hate waste. If they are considered good still, I want to use what's there. If they are toast after first use, I'll run to my parts guy and buy a set.
Thanks!
Thanks!
It's just a crap shot. Plenty of us have reused gaskets without leakage. Your not going to damage anything but torque correctly at the specified sequence is your best bet. If it doesn't leak, great; if it does you've only created twice the work which really isn't a lot in the case of upper rocker covers. I've used new gaskets that have leaked with all proper sequences followed. Give it a try. Now if it was a head gasket I'd say replace every time.
As was said above, not an o-ring. Orange RTV that was cured on the cover flange. You'll understand when you see it. If it's in good shape I have wiped it off with alcohol, skimmed a thin coat of orange RTV on it, reinstalled and not had any leaks. That being said, I do have a set of -99A's on the shelf for the next time.
I have done both... re-used & bought new... never had a leak. There is not that **** storm of oil flying around in there that one might think... more like a dribble kicked around by the rocker arms.
It also depends on whether the gasket sticks to one side or both.... it's a metal gasket so a dent or a bend means it's history.
Please keep us all posted with your results!
__________________
NO, they DON'T all do that!
Also on amazon.com...
