Special pump for airshocks?
The valves on the shockes seem to be shorter so a regular air chuck does not work. Is there a nice super expensive pump that HD sells to check this? I've got an air compressor with a regulator on it that I could drop to 5psi to do this, but the chuck doesn't seem to work.
Thanks
Thanks
RE: Special pump for airshocks?
Found it:
Touring Suspension Air Pump
This pump was designed to allow safe and simple adjustment of the front and rear air suspension on Touring motorcycles. Unlike a bicycle pump or a fuel station air hose, the hand operated pump with controllable "micro bleed" valve allows precise adjustment to air volume, and the "no loss" air connector maintains shock pressure when the fitting is removed. The 4.5" swivel air hose simplifies valve stem attachment. The aluminum housing is compact, lightweight and durable, and fits easily into your bag for "on-the-road" adjustments. The high quality 0-60 psi gauge ensures accurate air pressure.
54630-03A
For use with Touring Air Suspension components. Pump picture
MSRP US $39.95
54630-03A
MSRP US $39.95
I bought the H-D air pump and it works good. However, when I had the detachable King Tour Pak installed the air fill was moved to a lower position. Before, with the H-D pump, I could adjust the shocks without removing the hard bag on my Road Glide. Now I have to remove the bag to make adjustments. Anyone know of any kind of extender kit for the air fill?
BTW, I think I paid around $35.00 for my pump.
Thanks,
Ken
Thanks,
Ken
You may find that the washer and nut on the valve are what are causing the problem with not being able to fit the air chuck on the valve. It was a problem for most that if you either grind down the nut to half it's thickness or just find a thinner one your problem disappears.
Thanks,
Ken
Thanks,
Ken
