Clutch Slipping
I had a 107 kit installed last year and didn't realize how bad my clutch was slipping. I was like you, dropping from 6th into 5th and when getting on the throttle the rpm's would ramp up but not much increase in bike speed. I tried adjusting the clutch but didn't see much difference. Finally put an AIM VPC lockup kit in a few weeks ago and pulled the front wheel off the ground on my first roll out. No more clutch slip for me and I'm grinning from ear to ear now!
Same for me. I put Redline primary fluid in my primary and immediately clutch was slipping in 5th at any RPM, and a little in 6th as well. Switched back to non-synthetic and that didn't clear it up totally. Switched to the SE spring and everything is back to perfect. And yes, clutch was adjusted by my indy and by a Harley mechanic before switching the spring and fluids.
I appreciate the input guys, Ok I call my local Harley parts and the heavy duty spring says it's not for thr 14s up. But the parts looked up the spring that in the 14s and it's the same number as 98-13 wtf.
And like SafetyMan stated the clutch is not adjustable.
The HD spring number is 37951-90, they have it in stock, I need to know if this spring will fit the 14s?
Like I said I appreciate the info and may have to use an after market clutch, damn there high$, but would like to try the heavy duty spring first if I can find out if it will work in the 14s?
Yes 37951-98 I was talking to them on the phone, guess I misunderstood. Picked it up today at the local HD parts department, they were still telling me it won't fit my 14 limited because it's no in her book. So we go online to Harley's website and it says it will, I bought it anyway and they want me to let them know if it works. Going back to formula too.
