Rocker Locker vs Rockout
Both need to be made of a nylon material or other than brass. Any movement left in the rocker shaft will wear the brass and the tapping could gradually return. Or use 4 inserts, one on each end of the shaft to help ensure no movement is left.
Just installed the rockouts lastweek, have about 700 miles, most of the aggravating ticking is gone. It's not like a winter project job to install the inserts very simple.
https://www.hdforums.com/forum/new-r...s-over-22.html
Exactly what the physical differences are is proprietary, the reasons for my installation method are briefly explained here... https://www.hdforums.com/forum/touri...t-inserts.html
Full installation instructions are on my website in the link below.
If you are going to loosen all of the bolts, then pull 2 of them to install an insert, the extra step to install my way is to remove 4 more already loosened bolts. That's it. Then the assembly pulls right out & you can replace the O-ring, blow the oil out of the bolt holes as is IMO NECESSARY, and do the simple installation on the bench. Reassembly is as simple as the disassembly was.
Also, the price for my kit is $15, shipped. Theirs with shipping? I don't know.
Thanks for the interest, ride safe.
__________________
NO, they DON'T all do that!
Also on amazon.com...
TEN4T2 (11-24-2017)
[QUOTE=Bikerscum Products;14462042]The metal is different, the shape is different, the installation method is different with extra parts included in the ROCKOUT kit.
How is the metal your using different? And how is the shape different.I know your recommended installation method is different.The Rocker locker shipping is free which you probably already knew.Just curious.
[QUOTE=GTK;14462445]
As I said, the physical differences are proprietary. I've made many changes in my design before putting them on the market. As for the price, sorry but no, I don't know what theirs sells for shipped, now that it is being distributed through DK.
About no way a stationary shaft is going to punch through brass. Especially brass made for shell casings. Not enough pressure to ever wear out in my opinion, but time will tell...
No I don't own either brand.
Bikerscum"really hate that name" DK customs price of the Rocker Locker is 15.95 plus shipping.So you have the best price shipped and offer the breather o'rings.Also,your way of installing them is probably the best.I installed mine per your competitors instructions and have had no problems,but if I do another set for somebody,I will follow your procedure.
