Rocker Locker vs Rockout
Old 10-07-2015, 07:51 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,635 Likes on 1,180 Posts
Originally Posted by GTK
Bikerscum "really hate that name" .
Blame my mama
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 10-08-2015, 10:20 AM
Bmusg's Avatar
Bmusg
Bmusg is offline
Also, the price for my kit is $15, shipped. Theirs with shipping? I don't know
Bikerscum"really hate that name" DK customs price of the Rocker Locker is 15.95 plus shipping.So you have the best price shipped and offer the breather o'rings.Also,your way of installing them is probably the best.I installed mine per your competitors instructions and have had no problems,but if I do another set for somebody,I will follow your procedure.
I got the Lockers for $15 shipped and installed them with the top end off. Not sure why someone would do it without removing the rockers, it's basically 2 more bolts. For $15 why not give it a try, seemed to quiet the top end some but I also added 2 flats of pre-load on my adjustable pushrods.
Old 10-11-2015, 07:02 AM
Gwaxley's Avatar
Gwaxley
Gwaxley is offline
[QUOTE=GTK;14462445]
Quote:
Originally Posted by Bikerscum Products View Post
The metal is different, the shape is different, the installation method is different with extra parts included in the ROCKOUT kit.
How is the metal your using different? And how is the shape different.I know your recommended installation method is different.The Rocker locker shipping is free which you probably already knew.Just curious.
There are several ways to install the rocker arm bushing. When I pioneered the bushings there was no knowledge of how to install them. Our instructions have been modified numerous times over the last few months as we learn what works best.
We are in the process of modifying them again, as well as a new video describing it.
I have always said that on the bench is the best way to install the bushings, however there are certain bikes that the plate is hard to get off even when everything is loose. In these instances installing them on the bike is an option.
Oh yea Rocker Locker vs Rockout, same design; same material; same length; almost identical taper, I should know I designed both.
__________________
Old 10-11-2015, 09:15 AM
PTAG's Avatar
PTAG
PTAG is offline
Old 10-11-2015, 09:27 AM
Sponsor
Originally Posted by Harleycruiser
Oh yea Lockers vs Rockout, same design; same material; same length; almost identical taper, I should know I designed both.
The design is not the same, the material is not the same, the shape is not the same, and you DID NOT design my ROCKOUT inserts. They have evolved over time from MY continuous research and development.
Research like this....
Maybe you have the other half of that sectioned rocker support plate?
Old 10-11-2015, 11:28 AM
Ride my Seesaw's Avatar
Ride my Seesaw
Ride my Seesaw is offline
Received 1,657 Likes on 766 Posts
Glad I'm not the only one. I never know how to interpret it, is it 'Bikers ***' or 'Biker's ***' or 'Biker Scum'?
Anyhow, looks like a good product so I'm off to order a set.
Old 10-11-2015, 11:44 AM
Sponsor
Yeah, understand about the name. It's the name I was using when I posted way back about finding the source of the tapping, so I just continued using it as a sponsor. Maybe I should see if they can change it to ROCKOUT.
Old 10-11-2015, 12:07 PM
Bagger_Vance's Avatar
Bagger_Vance
Bagger_Vance is offline
Site admin can change your user name if that's what you want.
Old 10-11-2015, 12:39 PM
GTK's Avatar
GTK
GTK is offline
Go for it if your Mama don't mind.
Old 10-11-2015, 01:06 PM
Sponsor
Hmmmm.... interesting to see that the maker of the other product has now just about EXACTLY copied my installation method.
Speaks volumes.
Quick Reply: Rocker Locker vs Rockout
