Loosing too much oil
Ok have some news - the leak comes from the crankshaft Position sensor mount ,100% sure
Most probably the O ring is damaged.
Do you know if I can replace only the O ring and where to find one ? Can I apply Silicon there ?
Days of searching, checking and cleaning and at the end its the crankshaft sensor ...
http://partsfinder.onlinemicrofiche....b=6&c=0&d=2005 FLHR ROAD KING® (FD) CRANKCASE ASSEMBLY W/ OIL FILTER
then click on engine sensors with switches
crankshaft position sensor part number 32707-01B
call and see if that has an O ring - who knows
http://www.jpcycles.com/product/432-487
here is he oring..but you can prolly get it at lowes, home depot, etc.. just take it with you and match it up.... Also, sometimes the sensor can leak through the center part where the plastic meets the metal housing...one more thing, you might try just [carefully] tightening the sensor a little, who know it might stop leaking...
