A word about installing ROCKOUT rocker shaft inserts...
#71
Thanks for purchasing my Rockout kit, hope to have you tap free soon!
Rocker support bolts.... 18-22 ft. lbs.
Rocker cover screws.... 15-18 ft. lbs.
Breather screws......... 120-156 INCH lbs!
That is from my '15 Limited factory manual.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
06copbike (05-08-2016)
#72
#73
Thanks for the kind words, I'm very happy to hear they worked so well for you.
Please tell a friend
John @ Rockout.
#74
A quick note...
To those who purchased their kit on Amazon, if you are happy with the results I would really appreciate it if you would take a few moments & give the Rockouts a positive rating there. I wish I could direct the viewers there to these forums but it's not allowed under Amazon policy.
Thanks again to everyone for the awesome support you've given me here,
John @ Rockout
John @ Rockout
#76
Glad I saw this thread - I was going to do mine later today (already have the kit).
In going over this thread (as opposed to the other long one) I see it is also recommended to get new rocker cover gaskets and breathers? First time I have seen this.
Also - which section of the manual do I need to reference?
#77
Most of the info for this task can be found in the Top End section of a manual.
I let the bike sit for a few days (poor riding weather) to let the lifters bleed down. Then:
(1) remove seat
(2) remove console
(3) remove tank
(4) remove spark plugs
(5) remove rocker covers - gaskets may stick so have new ones in case
(6) set cam to bottom of cycle per instructions
(7) remove breather assembly - I replaced with new ones while in there
(8) loosen arm support plate bolts per sequence
(9) remove arm support plates - bolts can stay in place per John's instructions
From here, follow John's online instructions - DO clean out the oil in the bolt holes as damage can occur.
After the Rockouts are installed in that cylinder's rocker, essentially reverse the process. Just make sure the push rods are in the rocker arms as they should be.
The other cylinder is the same...just remember to set the cam to the bottom.
Hope that helps!
The following 2 users liked this post by Pine Tree:
Curt5811 (02-11-2017),
ROCKOUT Rocker Products (05-08-2016)
#78
Thanks brother, I couldn't have said it better myself!
To TwoBlue...
If you have the older cast type breathers (and I think you do) folks like to replace them with the newer stamped style while they're in there. The kit is only about $15 & includes the NECESSARY shorter screws if you are making the switch.
Please let us know how the Rockouts work out for you.
John @ Rockout.
To TwoBlue...
John @ Rockout.
#79
Just finished up and no more noise! (Thanks Rock out! )Since I already had the bike apart I also did the Baisley spring in the oil pump. I had SE 255 cams installed and one thing for certain the mechanic just rushed doing the job,used some new, and some old gaskets and bolt torque was all over the place. Happy now though! going to shower and go for a ride.
Be safe
Robert
Be safe
Robert
#80
