Wheels and Tires
for the rear the 18x4.25 a 160 will fit with minor shaving of the belt guard - it may not be the ideal size -- the 150 will work better -- I had the 160 andf 150 on previous bikes -- some 160 had a slight wobble some did not -- never had a problem with the 150 - I would suggest you not get the 3.5 rear rim -- why not a 21/18 set up?
Heard to many complaints with the 21 on the front, not only here but a few other places. Still tossing around the idea. Just trying to see if there are enough tires available in the right size range. Hell I might even stick the the stock size. Gotta get new wheels. Hate the spokes, want to go tubless.
Check out this link. It might help you with your decision. I have had the 21" for a year in a half and no problems but understand your concerns. You could go with a 19" front like the new baggers have a little more wheel and less tire since you want to buy a new one anyway.
http://www.hdwheels.com/Product.htm
Your front will take the current stock size front tyre, so is widely available in 130/70. For the rear, as lkr0 points out, you bump into clearance problems. I have found that 160 tyres in particular seem to vary widely across the brands (my Avon is actually 167mm installed), not only getting close to interfering with the fender, but also getting darned close to the belt. A 150/60 will give more certain results, unless you want to mess around to get enough clearance.
