Nagging Sound
Nagging Sound
I am not sure how to describe it but the best I can come up with is an exhaust leak somewhere.
Bike is a 2001 FLHTCUI stock with the exception of V&H slip-ons. It has 99500 and I have had it for the last 5k. The PO said it had top end service performed at 80,000 miles that included new cams, chains, push rods and chain tensioners and had all services up to 90k. I changed oil in all holes when I got it and just changed it again last week.
The noise I am hearing seemed to come about a month ago when I removed the slip-ons to do some cleaning/polishing.....I hand to use some encouragement, i.e. hammer to break them free. It is most prevalent during lower speeds/ medium RPM. I shot a video on my phone with it at an idle, more for the sound but also to give you all an idea where the mic was close to in relation to the side of the bike.
This may be nothing but the noise is driving me nuts. All seems to run fine and seems to have the same level of power since when I purchased it.
I am new to Harleys...still have a ZX11 but trying to sell as the there is no difference between that and the Harley...the Harley has it hands down.
If anyone hears anything out of the ordinary I would appreciate your thoughts
thanks in advance.
Rifleman
thanks in advance.
Rifleman
thanks in advance.
Rifleman
thanks in advance.
Rifleman
I was going to agree with Dawg and say to leave her home next time. Agree with the possibility at the Y pipe. You said you used some persuasion to remove the pipes and the vibration may have cracked the pipe up by the mount bracket at the Y on the rear head above the trans. Also if you reused the clamps again they may be stretched and no longer sealing, especially if theyre 14 years old. Did you use never seeze when you reassembled? This could help seal the joint, and at least make it so you dont need a hammer to remove them next time.
No O2 sensors on a 2001. HD recommends changing that slip on muffler clamp every time you remove it, but many like myself reuse it several times. If you haven't, try that first. And as mentioned already check the Y pipe to see if it's cracked. If you never removed the headpipe it's unlikely that the exhaust port gaskets were disturbed, but with 99K miles it wouldn't be unreasonable if they failed. Are you sure it's an exhaust leak? See any black exhaust soot anywhere?
I did use the same clamps and didn't put never seize on it but will when I take the off this weekend. I am not positive it is an exhaust leak but is the only explanation I could come up with. there is a little black soot but not a lot. Both when I disassembled and still some on the ends of the exhaust pipes, a little more on the right than left. I will keep everyone updated and again thanks for the feedback.
