2012 FLHTK Suspension
Hi all, just picked up a 2012 FLHTK and the previous owner changed the suspension to 1" lower Progressive 944's on the back and dropped the front 2"with progressive inserts. I find the ride rough ( we have crappy roads) compared to my 2003 FXST I had. I have tuned the rear to 1/2 a turn above the 1st ring. It's a bit better, but the front just hits too hard and sharp. He was 5' 10" and 250+ lbs and I'm 5' 10" and 195. Am I better going back to stock shocks. Mostly single up touring. Appreciate any suggestions. Budget is an issue, have to pay for this thing. LOL And if any of you have been to Manitoba, Canada, you will know about our shitty roads.
Take care and thanks.
They only offer a 1" lowered monotube set, although I've read some reviews where the combination (or lack thereof) might end up a little lower. http://www.progressivesuspension.com...u-2013-touring The drop springs they offer goes to a 2" drop. http://www.progressivesuspension.com...ng-kit-drop-in. Maybe you have just the springs. Many people like the monotubes. If you hold the front brake and rock it forward does the front end dive?
+1. Given he is heavier than you he may also have installed 2 clips in the mono's, which would account for a stiffer ride for a lighter rider. The only way to know for sure is to ask the previous owner, if that is an option, or take the front forks apart to see. In any case, any time you "lower" the suspension, front, rear, or both, you will sacrifice ride due to the decrease in suspension travel.
