If you install it yourself. WARNING when you drill the holes put a block between tire and fender. A few have drilled a hole in their tire .
Check you alignment well before drilling. It is not a hard job.
All the parts you need for the 07
Haven't seen this tread in a while, is it possible you have the part numbers for those parts? Or maybe you can point out the specific numbers on a schematic for me? Would be highly appreciated
I just need to know what parts I need the numbers for in the diagram lol, I'm unsure what is needed to mount the fascia and what is not needed in the picture I posted above
Try this link. It is the parts break down from a 2007 Street Glide.
