Adding rear facia to 07 road glide?
I just did this, here is what you need:
3596- SCREW, SADDLEBAG BRACKET (PACK OF 10) - 3596 to hold in tribar light (Need two)
7499- NUT, FLANGE, CRUISE CONTROL (PACK OF 3) - 7499 (Need 6)
59778-06- GROMMET, REAR FENDER - 59778-06 (Need two of these or the plugs, depends on if you have tour pac docking hardware or not, grommets if so, plugs if not, or one plug one grommet if you have rear mounted antenna)
59749-06- PLUG, REAR FENDER - 59749-06 (See grommet above)
59818-06- STUD PLATE - 59818-06 (Need two)
59790-06- SUPPORT, FASCIA/REAR FENDER - 59790-06 (Need one)
69375-06- REAR FENDER LIGHT ASSEMBLY
And you will need the fascia of your color choice
59739-06DH is vivid black. If you need another color look at an online parts finder. You can only get it in a color that was offered on a street glide from the factory.
Good parts fiche here http://www.granitestateharleystore.c...7c%7e1OF2%5cKB
I recommend Boardtracker HD http://www.boardtrackerharleyonline.com
Awesome thank you!!
Is there a spot on my 07 the tri bar light plugs into or will I need to splice it?
