01ultraclassic
Old 09-27-2015 | 03:50 PM
jandjpowdercoating's Avatar
jandjpowdercoating
1st Gear
Default 01ultraclassic
I Would be riding then for no reason the bike loses power i mean everything then I wait for about 2to3 seconds the bike starts back up.i can ride for another 30min or longer and it will do the same thing again any ideas?
Old 09-27-2015 | 04:04 PM
MGN54's Avatar
MGN54
Electrical power or engine power?
Old 09-27-2015 | 04:24 PM
jandjpowdercoating
1st Gear
I lose everything electrical and motor the entire bike shuts down
Old 09-27-2015 | 04:30 PM
gomiller2's Avatar
gomiller2
could be your crank position sensor is going bad.
Old 09-27-2015 | 05:15 PM
jandjpowdercoating
1st Gear
Default power
OK this is a new one on me where is the sensor located
Old 09-27-2015 | 05:49 PM
bdtaylor1979's Avatar
bdtaylor1979
Check your battery cables and makes sure they are tight.
Old 09-27-2015 | 07:05 PM
lt1-xjs's Avatar
lt1-xjs
On the engine casing by the oil filter. Sometimes they just need cleaned. A full power loss is usually a bad main circuit breaker, under the seat in front of the battery. Replace it with a 50 amp.
Old 09-27-2015 | 07:08 PM
jandjpowdercoating
1st Gear
Thanks
Old 09-27-2015 | 07:14 PM
Stiggy's Avatar
Stiggy
There was a recall on the 40 amp main fuses for late 90's early '00's bikes. Check with a dealer and see if your bike qualifies.
Old 09-27-2015 | 10:18 PM
Bill03E's Avatar
Bill03E
Yeah the main circuit breaker, but also change the ring terminals on the silver stud as they heat up , and cause the circuit breaker to trip. buy a new circuit breaker, and some big fat ring terminals, and replace.
