Rear brake squeak 2015 SGS
Well... you are paying for the annoyance... so, like others have done... I'd try to correct it but its your choice as to the dealer or home remedy.
Personally... I'd spray it out with brake cleaner, make sure the float on the rotor didn't bind up (it should be able to be moved with finger strength up and down).
If that didn't fix it... I'd bring my baby back in. enjoy the popcorn, sit in those comfy couches... maybe they will swap out the semi-metallic pads which I suspect may be the cause.
Mine did the same after 500 miles. I heard once upon a time that you have to file the edge of the pad down. I'm going to try it next week when I take my back wheel of to get a new tire. I'm so tired of hearing the squeaks of the rear pads. I've tried break clean dosnt help.
That took care of the problem. It appears to have been a high frequency oscillation problem with the pads, based on the appearance of the backing plates. I'd give it a try, it doesn't cost much and fixed my problem.
I hate brake squeal and similar noises. I put up with it for quite a while before finally coming up with a solution. I was skeptical about coating the backing plates, but it worked for me.
"Took the pads out recently and chamfered the leading edges and sprayed the backing plates with CRC Disk Brake Quiet."
I will do this with the EBC DoubleH Sintered pads I bought... sound like cicadas when I apply the brake.
My bike is down for at least another week... so its a good time to do ish like this.
