Target tune for power vision
I have been looking into it also. Been using TTS for the last 3 years. It is a great tuner don't get me wrong. Having traded up to 15 RG, it's time to start over. From what I have read it is very accurate. The tt gets mounted on the bike and stays there until you change the bike, then you can transfer it over to the next one. Some won't like the big sensors but... The advantages seem to outweigh that point. Having the the ability to lower the afr below the traditional closed loop sensor range is a huge plus. With the wide band sensors the range is huge, you can tune the bike with more fuel to help keep it cooler and still have the ECM monitor and make adjustments as necessary. I ride in areas with a lot of elevation changes, to me it is important for the ECM to be able to make adjustments. It's early in its development but it is a huge step for self tuners.
