run stop switch??? mabe
Old 09-17-2015, 03:35 PM
jmn1960's Avatar
jmn1960
jmn1960 is offline
Originally Posted by RIPSAW
Would check the battery cables first. Could be a loose poor connection. Enough to drive all except starter solenoid. As you kept trying, the loose connection heated up the sorry connection expanding it to make. That on/off switch is pretty low amp and should be OK. Know you are suppose to use it but I never do. Just the key switch.
checked all cables both ends ,, last night, all tight and clean, also checked starter mount bolts also clean and tight.
it was just that I had power to all but when I hit the start button nothing happened. so I rocked (on -off)_the run stop engine switch with the start button pushed and it made contact and started,, that is what leaned toward the run stop switch..
thanks mike
Old 09-17-2015, 03:50 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
you have your piece of wire and knowledge, just ride as you have a "work around"...this may never happen again.
or it may get worse- at which point tear stuff apart
mike
Old 09-17-2015, 03:55 PM
jmn1960's Avatar
jmn1960
jmn1960 is offline
mike
cool thanks again to all
thanks mike
Old 09-17-2015, 08:02 PM
2AMGuy's Avatar
2AMGuy
2AMGuy is offline
Received 3,302 Likes on 1,861 Posts
My 2000 Ultra, with about 75,000 miles on it suddenly got hard to start and several times it quit when I was riding it.
The last time it quit on me I was almost in my driveway, but I live on a dirt/gravel road that has an incline and I wasn't about to push it.
After "playing with it" for a while, it started and the next day it was on the trailer and on it's way to the dealer where I bought it new.
I imagined all kinds of serious/expensive possibilities but it turned out to be the "kill" switch!
Everything wears out eventually.
Makdaddy
Audio Systems
02-01-2017 10:50 AM
Chester Zielinski
07-10-2015 09:59 PM
kenporick
09-20-2014 01:22 PM
stbob07
12-30-2013 09:21 AM
onemyndseye
01-07-2012 09:55 AM
Quick Reply: run stop switch??? mabe
