Base gasket leak it not covered under warrantee? WTF!!
Hello everyone. I've got at 2014 SGS and I'm pretty sure it was built on a Monday. So far I've stripped 2 shifter shafts, had an inner primary leak and now a base gasket leak. They've warranted everything but are now refusing to cover the base gasket leak, saying its seepage and it's not covered under the warrantee. Needless to say I'm not very happy. Does anyone have any advice on how to navigate this with the MoCo.
If the motor is stock...The first question is... is it the Dealer not covering it or directions from the MoCo saying not to cover it. The majority here will say its a motor related gasket defect and should be covered like any other issue. ie: rocker covers, primary, etc.
Sometimes a lawyer is your only defense but unfortunately, unless you know one that will do you a favor & write a letter. The legal fees can be far more than the cost of getting it repaired. Good Luck
As stated above, a Twin Cam motor doesn't have a "gasket" per se on the bottom of the cylinders. It has an o ring that is covered with assembly lube when it's built. When the bike is new (as described above) it will weep a little lube. Clean it up and keep an eye on it. If it's really a leak, it'll become apparent soon enough. If it isn't then you didn't spend a lot of time being frustrated over nothing.
First, there are no base gaskets, they are o-rings.
Second, what does it look like? Oten its just excess assembly lube from the factory and it goes away.
Here's what mine looked like with less than 1000 miles on it. I sprayed brake cleaner on it, and it has not returned 30K miles later.
