Road King ignition switch cover hinge pin
Old 09-14-2015 | 05:13 PM
bigheadted's Avatar
bigheadted
Default Road King ignition switch cover hinge pin
Stropped for lunch, reached down to shut off the main switch on the tank and the cover came off !! The pin appeared to have fallen out but at least the cover was still there.
I cannot find replacement hinge pin, can anyone confirm a replacement is available ??
If not I will hunt a roll pin down to try.
I am a shallow pocket enthusiast for 30 plus years so am not going to go to the dealer for a entire new assembly.
Anyone ????
Old 09-14-2015 | 05:20 PM
dawg's Avatar
dawg
Old 09-14-2015 | 06:45 PM
bigheadted's Avatar
bigheadted
Thanks Dawg !! Just the sort of hillbilly engineering I do !!
Old 09-17-2015 | 11:11 AM
bigheadted's Avatar
bigheadted
FWIW if anyone cares I ended up not finding a roll pin that would work and ended up using music wire which fit perfectly snug.
I cut it to length, used a file to knurl the ends and coated with lock tite. Worked great.
roundy
11-17-2015 04:44 AM
roadrage12
12-04-2014 05:51 PM
uklauren
01-19-2014 07:25 PM
pitbulldog
09-28-2010 08:27 PM
waterwalker
09-21-2010 01:09 PM
Quick Reply: Road King ignition switch cover hinge pin
