Doing cams now and FM 107 later. What cams to choose?
Old 09-11-2015, 10:18 PM
Olsen185's Avatar
Olsen185
Olsen185 is offline
Default Doing cams now and FM 107 later. What cams to choose?
I have a 2015 SGS that I plan on eventually adding a fuel Moto 107 kit and ported head to, but for now just gonna do cams. I thought I was set on a set of Woods 777, but then I noticed the 888 cams. I will call FM, but they are closed till Monday. Until then, any real world experience with the 888?
Old 09-11-2015, 10:23 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
wait and talk to them, do it all at once do it right.
2.) this will likely pooch your warranty- waiting is a smart thing to do.
Mike
Old 09-11-2015, 10:30 PM
Olsen185's Avatar
Olsen185
Olsen185 is offline
I will be taking my time on the 107 kit as a winter project, but I want the extra power from the cams now. Cams should only take a day or so and there is still a lot of good riding weather left here in NJ.
Old 09-11-2015, 11:08 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,846 Likes on 1,085 Posts
Money burning a hole in your pocket? I'd wait and do it in one shot.
Old 09-11-2015, 11:21 PM
Olsen185's Avatar
Olsen185
Olsen185 is offline
I'm asking for advise on cams not if I should do it all at once or not.
Old 09-12-2015, 12:07 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
Tman totqster and and set of Baisley superstock heads set for 10-1. Difference in power from a 107 would be negligible, and you'll have a very reliable motor.Add a 31 tooth Balker pulley for a little icing. Those are heavy bikes ,don't overcam. Have fun......
Old 09-12-2015, 09:09 AM
OldEnuf2NoBtr
Just trying to save you about $500-$700 dude. It's your money, waste it as you want to.
Old 09-12-2015, 09:20 AM
pittz5's Avatar
pittz5
pittz5 is offline
If your doing the work yourself I'm not sure how your saving money by doing it all at once??? I do my own work and would do cams now if that's all you can afford. No experience with the 888 but I loved the 777 I had in my 106 kit. Ran fantastic with good low end and took off like a rocket at 3k. Good luck on build.
Old 09-12-2015, 09:37 AM
gipper's Avatar
gipper
gipper is offline
OP: In your header you ask "what to choose", and in your post you ask for real world feedback on Woods 888's.
You're appearing to be fragmented, which does set you up for unsolicited advise.
I have no real world experience with the 888's, but I do the 222's if you're interested, which are in my bike now.
There is no one that can help you with "choice" until you've defined where you want your power to be made, and what you're looking for. I haven't read up on the 888's but I do know that the 777's are at their best with higher compression than stock levels give you, and are that which I've chosen for my own FM 107 Kit. So, you can see too, that there are other factors that will influence how your cam choice will perform now as opposed to how those same cams WOULD perform when you do your 107 Kit. I start my build in 1-2 weeks, and I'll have done cams twice when it's all said and done by virtue of the fact that TW-222's perform better at stock compression levels than the 777's would have prior to building my motor up to a 107. That is of course, based on the low end torque that I wanted when I installed them two years ago.
No unsolicited advise from me on how you spend your money or your time, but hopefully a little constructive input. Good luck.
Old 09-12-2015, 10:33 AM
KSGLIDEGUY's Avatar
KSGLIDEGUY
KSGLIDEGUY is offline
I have a 15 RGS and have been looking at cams also. I don't have any experience with the 777's but I do know they work well with the stock 103 and even better with the 107 kit. They also have a new 999-6a cam which Jamie has been recommending alot. It also works well with the stock 103 or the 107 upgrade. I am leaning towards just going with the 777's .
Quick Reply: Doing cams now and FM 107 later. What cams to choose?
