Wild Chubby's...???'s
Old 05-03-2007, 09:58 AM
zorro's Avatar
zorro
zorro is offline
Default Wild Chubby's...???'s
Bought a set of W0517 for my Roadie - Although, the web site says no cable changes needed I ave been told the brake cable WILL NOT reach - anyone else who has changed out to these no anything about it...???
THX
Old 05-03-2007, 11:06 AM
texas tom's Avatar
texas tom
texas tom is offline
Default RE: Wild Chubby's...???'s
You should be able to make brake cable reach if you carefully bend the line,ive known several people that did that,me I like braided cables cost about $130 but they look good...
Old 05-03-2007, 11:22 AM
zorro's Avatar
zorro
zorro is offline
I just sent the bars off to be powder coated (black) -
But my wrench (not a Harley dealer wrench) said hehas changed them out before and needs to buy and make a longer brake cable - He told me he has had technical conversations with Wild1 about this very topic - ???
Old 05-03-2007, 12:13 PM
HogBoy's Avatar
HogBoy
HogBoy is offline
I have Wildchubby's on mine, but braided steel cables went on as well. Mine are not your model, however.
Old 05-03-2007, 12:18 PM
zorro's Avatar
zorro
zorro is offline
where oh where can I get a set of braided cables for both clutch and brake ... for decent $$$...
ZZZZZZZZZZZZZZZZZZZZZZZZZ
Old 05-03-2007, 12:21 PM
HogBoy's Avatar
HogBoy
HogBoy is offline
ROFLMAO....the first part is easy. It's the second part you may have problems with.
Old 05-03-2007, 07:41 PM
Manish_Hawg's Avatar
Manish_Hawg
Manish_Hawg is offline
I will recommend Shooter64. He is a member on this forum and he has good prices. My cables arrived today.
2nd I am installing Chubby's on my bike and I WOULD NOT take Chubby's word for the cable length. Mount your bars and measure. This topic was discussed a while back and 1 person ordered a cable that was too short (listening to Chubby), and 1 person had a cable that was such a tight fit that it broke after 1 year. Chubby told me I needed a +4 Idle and a member on this forum said he need a +8 (we had the same set up). I decided to measure and I needed a +8. Better safe than sorry! Mount and measure.
Old 05-04-2007, 01:49 AM
buttman's Avatar
buttman
buttman is offline
I put the 517's on my 04' RG, and all of the stock cables fit. You will have to straighten out (bend) the brake line to make it work. I didn't like that, so I put braided lines on. Iused +6 clutch, throttle, and idle cables, and +4 brake line. My clutch cable is a little long, you could probably use a +4 for it also. Having the wiring inside the bars makes it alot cleaner!
[IMG]local://upfiles/8977/20EF60FA785B4B0A81C4CE39E8CFCE19.jpg[/IMG]
Old 05-04-2007, 02:40 AM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
Put WO517's on my RG without changing the cables or lines... But had to do some creative bending on the front master line... But it worked...
Old 05-10-2007, 10:26 AM
zorro's Avatar
zorro
zorro is offline
I have a Tech telling me there is NO WAY these bars can go on without changing the cables. He's also telling me it will cost about $600 to do the job - $200 to make the cables HUH???[] and $400 in labor costs...I am really, really, really bullshit about this as I bought these "F-ing" bars in good faith based upon the Wild 1 website claiming no cable changes are needed WTF!!![:@] Here is the AD taken directly from their website ...
FYI - Update... I spoke to the GM of Wild1's (Chubby's) today 05/10/2007 - He told me that the owner of the Company was supposed to change the language in the AD to reflect "May need to change cables" However, after I pointed out to him that it wasn't changed as of today's date and when I purchased the bars a month ago (and he could clearly see that) - he agreed to refund all of my money plus shipping and take the bars back -
CHUBBY® R.G. BARS
PART # WO517
Sensational 1 1/4" thick customs for the Road Glide. Designed for maximum comfort and control. They are 31.0" wide, with a 14.5" pullback and 8.5" end rise. They work with the stock Controls, Grips, Cables, Brake Line & Wiring.
Retail Price $209.95.
Quick Reply: Wild Chubby's...???'s
