Wild Chubby's...???'s
RE: Wild Chubby's...???'s
if your dealer is telling you that the WG bars will fit with out bending the brake line then think again... look at your brake line, it follows the stock bar - any other shape bar will need to have the brake line bent... Two other posters said the 517's would fit (yes the brake line has to be bent) but the other cables work fine... I guess you don't want to believe them. If Wild1's told you that the bars would fit with NO adjustments at all then you have a case - that is Not what was told to me when I called - I went with a different brake line... I promise you if I can do this swap then "anyone" can... I enjoyed the work it took and was proud to say "I did that" when it was all over. I put Wild1's 575 on my EG and when I got a RG I have had both the 513 and the 517 on it... Its really not that hard. You will like the WG bars - just the wires will still be on the outside - on the chubbies they would be inside...
Life is short - enjoy...
harley 0711, I can't get any info from wildI. i think they have the chubby 502s with the wiring inside but I can't seem to get any info on the clutch and brake cables,ya know if I have to change them or what length to get if I do I have 8 inch bars on 2000 road king.can anyone enlighten me?
thanx, Archman
thanx, Archman
