Daymakers??
Daymakers??
I am wondering if anyone has purchased the "Daymaker" from baggerbags? and if they are as bright as they say. maybe you have experience with theseof know someone who has. Lets face it, for the price it is definitely affordable. I have read that in some cases you have to trim the stock rim or purchase their trims. I am about to pull the trigger for my 15 RK.
Daymakers are bright
I am wondering if anyone has purchased the "Daymaker" for baggerbags? and if they are as as they say. maybe you have experience with theseof know someone who has. Lets face it, for the price it is definitely affordable. I have read that in some cases you have to trim the stock rim or purchase their trims. I am about to pull the trigger for my 15 RK.
After market Led"s...
A buddy bought an after market 7" LED... He had ninor modifications to do as they are not necessarily OEM. Good luck.
Ditto on the evo 2's. $276 on amazon and newer and brighter than the daymaker. Plug and play, depending on year you may need the mount ring for another 50 bucks.
Check out the Fuel Moto LED set up
Put the low beam and passing lamps for $120 and change and has transformed the visibility
Was actually heading down the path the op is going and ended up where I did
There is a couple of detail threads in the Rushmore forum
Almost forgot - no work all plug and play in and out in 15 minutes
